naw, just ones that don't get noticed
guess not many check in this forum regular
removing the glass will make them lighter, but one person can lift a door OK, just won't want to carry it far, or long
if you take the bolts off the hinge side on the door itself while the door is closed, you can gently open the door and slide it off the hinge ends, then remove the hinges from the pillar ... reverse that to re-install ... works for me
