| | | Forums66 Topics128,089 Posts1,056,116 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 18 New Guy | | New Guy Joined: Jan 2008 Posts: 18 | I have a GMC '48 453 with a 270 engine. Are all the exhaust manifolds the same size from the 228 to the 302 size? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | An oe part number 6107434 fits 228-302. It was superseded by 2194274. I think a later 302 has a larger exhaust flange but I think they would all bolt to the head. | | | | | Joined: Jan 2008 Posts: 18 New Guy | | New Guy Joined: Jan 2008 Posts: 18 | the exhaust manifold casting no# on ours is 2180407P any ideas on whether I could use a manifold off a 248? | | | | | Joined: Jan 2008 Posts: 18 New Guy | | New Guy Joined: Jan 2008 Posts: 18 | Our manifold had a 3 bolt exhaust flat flange with preheater counterbalance | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think they all had a 3 hole flange and a heat riser. Casting numbers are not necessarily part numbers and different parts books use different part numbers due to revisions. Gasket sets were sold to fit 228-302 but some gaskets were not used. I think the exhaust gasket was the same, but the intake was larger on a 302. I still think a 302 manifold would fit your 270. | | | | | Joined: Jan 2008 Posts: 18 New Guy | | New Guy Joined: Jan 2008 Posts: 18 | Thank you,our manifold was found cracked in half and are trying to find another. As always you all have helped to make our dream come back to life! | | |
