3 members (5 Window 9434, BC59, 66flea), 158 guests, and 3 robots.
Topics128,087
Posts1,056,107
Members48,434
I have a GMC '48 453 with a 270 engine. Are all the exhaust manifolds the same size from the 228 to the 302 size?
fireman290
48 GMC 453 Howe firetruck
http://community.webshots.com/user/fireman290gen
An oe part number 6107434 fits 228-302. It was superseded by 2194274. I think a later 302 has a larger exhaust flange but I think they would all bolt to the head.
the exhaust manifold casting no# on ours is 2180407P any ideas on whether I could use a manifold off a 248?
fireman290
Our manifold had a 3 bolt exhaust flat flange with preheater counterbalance
fireman290
I think they all had a 3 hole flange and a heat riser. Casting numbers are not necessarily part numbers and different parts books use different part numbers due to revisions. Gasket sets were sold to fit 228-302 but some gaskets were not used. I think the exhaust gasket was the same, but the intake was larger on a 302. I still think a 302 manifold would fit your 270.
Thank you,our manifold was found cracked in half and are trying to find another. As always you all have helped to make our dream come back to life!
fireman290
