5 members (52Carl, GradyB, GRNHydra, Pre '68 Dave, DadsFirstPickup), 82 guests, and 1 robot.
Topics128,080
Posts1,055,944
Members48,430
#422527 06/12/2008 11:01 PM
I have a 46 Chevy truck and notice only one support rod going from the firewall to the radiator! Isn't there supposed to be one on each side??
Where can you buy them at??
Dan
Wharton, TX
yes there is supposed to be one on each side.
check with jim carter or american classic, if not maybe some one has a parts truck and could sell them to you. mine are bent out of shape, so i am sort of wondering the same thing
Ron, you are right there should be one on each side, only the whole affair is one piece. It's a "V" shaped rod and goes from one side of the firewall to the raditor frame then back to the other side of the fire wall.
Hope this helps
George
