| | | Forums66 Topics128,033 Posts1,055,531 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I've been reading the various information on here regarding 22.5 inch tires being the tubeless replacement for the old 20 inch tires.
One of my trucks (not a bolt, in case that matters) has 17.5 tubeless tires on it, while the identical parts truck has 16 inch tires. Is this the same scenario as above?
Are these 17.5's hard to come by? I'm just curious, as I may need to replace a couple, and I was not aware that this size even existed until I got this truck. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Correct, the 17.5" tires are the tubeless equivalent to 16" tires.
New 17.5" tires are out there, but can be hard to find and expensive. I did sell a set of seven 17.5" wheels from a 61 ford I had to someone who wanted to go tubeless even considering buying the rims from me, shipping to AZ, and finding the expensive tires, I even had a few other folks waiting in line if the first guy did not take them. Personally I would not buy or mess with 17.5" tires, but I also have not been in a situation where that was my only tubeless option...
Grigg | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Thanks, Grigg! I had kind of suspected that that was the case. Funny you should mention Ford. This truck happens to be a '59 F-350. I'll keep this info in mind if I have to go tire shopping. If necessary, I'll just go back to 16", since I have a complete set of rims on my parts truck. I really don't care if they're tubeless or not, as long as they hold air!!  | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | 16" tubeless are everywhere, and cheap. 16.5's are less so. 17.5's are, like Grigg says, not common. I have 235/85R16" tires and they are only 1" shorter in overall height than the 7.00x17" originals on my '51 3800. 1951 3800 Be the change you want to see. -hotshoe
