Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (DaveV, jmoore, baldeagle, dt235sd, Lostbuthaulinass), 45 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#416095 05/23/2008 11:22 PM
How do you remove the old throttle and choke knobs from the metal stems. I want to put my old 1940 knobs on new cables.
I don't know if you can remove them from the old cable, you can order some new ones that look pretty good frpm Jim Carter.
Ed
Ex Hall Monitor
Ex Hall Monitor
Double posting is frowned on by the Mods. Check the answer I left you in the Paint and Body Shop forum.
Apprentice
Apprentice
how about removing the old broken knobs from window crank handles? what is the best way to do that?
It has been a while since my teardown but I believe there is a set screw for the door and window handles.
~Jim
I just drilled mine out from the back. Takes about 1 minute. Metal is very soft.
Moderated by  ndkid275, Phak1
