| | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Hopefully this will be quick. I've got a pretty good original radiator that I'd like to restore. I was thinking about an acid dip and then some radiator paint. I've never asked a shop if they do this sort of work or just patch holes. Any experience/advise out there?
Dave
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a good rad shop will clean it as necessary, leak check it [many/most old rads weep or are weak at the tank joints], repair it if needed, and repaint it with the proper paint
Bill | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | When I worked at an antique car restoration shop we would take the radiator to the radiator repair guy, he would disassemble it and keep the core, sending back the tanks and side straps. We then straightened the dents out of the brass tanks. Occasionally the tanks would have to have cracks silver soldered, or new parts made of brass and silver soldered in place. We also replaced portions of the steel as necessary or remade them altogether. Then take all the bits back to the radiator guy, and he would carefully reassemble it, then one last check for dents, a scuffing, and paint.
You may have to look pretty hard to find a radiator guy who is that careful and accommodating.
Grigg | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Check with a local rod shop; there must be a thousand in California. Ask them who they use for radiator work. That shop should be above average.
~Jim
