7 members (Ponchogl, Otto Skorzeny, moparguy, KEVINSKI, Brian Moore, 55shaker, ShopRag),
71
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | The guys who are installing our new hickory floor are using one of these, to finesse the trim and to do detail work. It is a very nice tool, saves them hundreds of hours in a year.
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Interesting. I've seen sanders that look like that for some time but not with the cutting attachments. It looks like the kind of tool one wouldn't need often but would be really handy when you DO need it.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | dang!!! I got too much invested in tools already .... but I'll watch for that thing on sale at the local tool place  Bill | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i have a sander that looks like that made by ryobi absolutley hate it..............................dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Explain, hate it. They look like they should do a good job of sanding in tight corners.
'67 GMC 3/4 292 4spd
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | "looks" like it should is about right.used to do a fair amount of woodworking.had a friend that did also ,he had upgraded some tools and gave me a few of his tools.this sander was one of them.it just doesnt seem to sand good.i dont think my expections are to much.yes you can get the tip in tight areas but the particular one i have just doesnt sand worth a crap.am really glad i didnt pay for it and suspect thats why he gave it away.not being one to look a gifthorse in the mouth didnt want to ask if he thought it sucked also............dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jan 2007 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 48 | Replacement blades for the multimaster are way overpriced.
Joe -------------------------- '67 Chevy C20 fleetside, 250 inline, 3 on tree, heavy duty clutch and brakes, heater, steel bed floor ----------- "Tighten until the stud snaps, then back off half a turn."
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I have an older Craftsman sander just like that.Fein tools are very good stuff but very pricey.I dont know if the newer Craftsman sanders are worth bringing home or not.Mine has worked just fine for about 15 years. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I found a Fein in a pawn shop a while back and the pawn shop didn't know what it was, so I got it cheap. I also do wood working and furniture restoration as a hobby. After using one, I would pay the retail. | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I was watching "Dr. G, Medical Examiner" She uses a tool just like this to remove the tops of skulls.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I use this tool often, the blades are very expensive, some are over $20 for one. They wear out quickly if you hit a nail. Lot's of uses too, tile, raising the door moldings to allow for tile or flooring, cutting wood for access. I didn't think i would use it as much as I do. It's a great tool, very expensive, but worth having if you are in construction. | | |
