0 members (), 44 guests, and 4 robots.
Topics128,077
Posts1,056,013
Members48,433
#42186 03/27/2004 9:25 PM
After putting it back together and it wanting to idle at about 3k I finally got somehelp from the carb guy I found that the intake manifold wasnt flush with the head and all the air was coming in there, after a quick adjustment and a new set of intake/exhaust gaskets it runs fine, so all I have to do now is have the carb guy adjust my carbs, I've been trying for a few days and just cant get it straight, anyway thanks for all the help guys
#42187 03/28/2004 6:45 PM
Don't you just love it when a plan comes together:).
#42188 03/28/2004 10:05 PM
Yeah after about 2 weeks of headaches and the car being ripped apart all winter, anyway the carb guy needs to rip into one of my carters and after that he says everything will be running perfect, the idle is messed up on the one carb, he said something is blocking a passage in the carb
#42189 03/29/2004 1:07 AM
Any luck yet finding an air cleaner to fit?I ve been useing a 3 inch and cuting em in half.You can always trade me for a stock manifold and cleaner...
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#42190 03/29/2004 7:01 PM
I am going to go with 2 stock aircleaners, they both kind of angle fwd, the front one is going to hit just slightly but overall it will work, I am trying to figure out how I am going to mount them underneath, I am sure this makes no sense, I will post a pick of the setup once I get it done.
Both aircleaners are factory 58 biscayne 235 aircleaners if theat helps at all
#42191 03/30/2004 4:27 AM
