1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#42161 12/04/2001 12:43 AM
Junior Member
Junior Member
Hello,
I have a 60 model c20 with an old 235 in it. What newer model motors (v6 or v8) will bolt to my old bell housing, and who has the motor mounts to make it easy?
Walter [email protected]
walter
#42162 12/04/2001 1:13 PM
You might want to look at post titled"age old tranny question", I was told that bell housing bolt patterns changed in 63.
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
#42163 12/18/2001 8:07 PM
The only bigger engine that fits your bolt patterns are the 261 and bigger GMC ones, no V6 or V8 will bolt to your tranny.
Alexandre Garcia
#42164 12/18/2001 10:27 PM
The problem is not bolting to the tranny, the mating of the engine to the bell-housing
is where the difficulties lie.
The tranny will fit either bell-housing.
#42165 12/21/2001 1:02 PM
Excuse-me, I made a mistake. What I meant was: In place of a 235L6 You can only bolt any other stovebolt engine, be it a 261, or a GMC, for example a 302. No V6 or V8 or even a 230/250/292 won't fit. The trouble lies in the fact that the earlier sixes do not have a flange cast in the block as the newer 250, for example have. By the way, these flanges in the 230/250 are the same as the V6 90' and all the V8's, small, W or big block.
The bellhousing of a 235 will only accept stovebolts. No way to use another engine in it.
Alexandre Garcia
#42166 12/21/2001 1:37 PM
Along those same lines, try this link, http://classicchrisengineering.freeservers.com/50chevyHome.htm Then click on "Related projects and web sites" then click on www.chevytrucks.org Once there click on their tech section. They have a really good article on putting a S-10 tranny in an older truck. grin
[ 12-21-2001: Message edited by: 6T2Burb ]
1947 Chev Coupe
1969 GTO ragtop
#42167 12/21/2001 1:55 PM
The issues stated above are a HUGE reason why I stay with the '64 and up chevy trucks. None of these compatibility issues and having to go around the world and back just to get your vehicle suitable for daily driving.
Rebuild your 230/250/292, bolt a 700R4 behind it and you're ready to drive anywhere! grin
#42168 12/21/2001 2:24 PM
6T2burb, You can make it, in fact sometime ago I assembled a T5 out of a Mustang in a chevy engine. I don't know what bolt pattern You can have in a T5 out of a S10, if it has the old desing with the for bolts hanging it to the bellhousing, it's ok, if not You'll have to make an adapter.
To match the Ferd T5 to the Bowtie I just used a 1" aluminum spacer. It worked very well, no problems.
Alexandre Garcia
#42169 12/21/2001 5:10 PM
Now just a minute here...
...a pre-1963 Stovebolt, in good condition is just as "driveable" as when new...
wink
...problem is, the world goes just too darn fast now-a-days :rolleyes:
As a "driver of old iron" since I wuz 17, until recently, my daily drivers were at least 25 years old.
This includes the 1948 Chrysler I drove while at college (frequently drove it between Baltimore & Wilkes-Barre, 200 miles on the I-state), the '50 Chevy Fleetline sedan, the '55 De Soto, the '48 IHC, etc, culminating with the present 1941 De Soto.
True, pre-'60's iron doesn't much like the super highway, but frankly, now commuting 50 miles each day on I-81 where people just seem to be in a hurry to meet their maker (and take me with 'em!), I often consider taking the "senior" car and sticking to the U.S. & W.P.A. roads, and enjoying the ride! cool
Now, back to the original question, yeah, nothing post '63 bolts to pre-63 where bell housings are concerned.
Conversely, there ARE post-'63 engines & bell housings that will bolt up to the older trannys.
There's more lee-way with trannys, and the angled rear-mounts of the post-'55 sixes and eights do fit the '54 cross-member, you'd just have to come up with side mounts for the front.
I don't think I've even pulled the bell housing of a 235 or 216, except to put the block on an engine stand; it's a pain!
You've gotta pull the flywheel to get at the bolts! :mad:
I'm curious about putting the later 6 in an AD, since it will take the higher revs accompanying the stock rears better than the older engine; or...
..finding a tranny/rear combo that'll keep the revs down at highway speed so I can keep the old mill; or...
...maybe I'll just keep it stock & drive slow, and annoy all the "important" people behind me in their SUV's :p
Frank
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
#42170 12/21/2001 5:22 PM
Quote
yet another good point. Thanks Frank. Didn't think about that one. grin
I've driven my '66 w/230 on the interstate for over 100 miles, taching at LEAST 3k the entire trip. And I've done several 50-70 mile stretches taching 3500 rpms. Totally stock! No problems whatsoever. :p
-ftyler
#42171 12/23/2001 6:49 AM
A WIMPY T5 trans won't be any good in a C-60 series 2-ton truck, Sheesh! :rolleyes: Use the same univesal mount kits for a p/up sold by all the vendors and you will need to make a trans tail mount to go with it. OR, find a bellhouse from late 50's trucks with ears on them and make/use the small mounts on front of engine or probly could use same side mount x-over kit like I mentioned above. The bellhousings from 55 to 67 all have the same size center holes for 4spd trans. After that they have a bigger hole for newer 4spds. I vote to rebuild the orig six and re-install! :p smile
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#42172 12/23/2001 6:52 AM
OK! OK! So I misread it was a C-20 instead of a C-60!!!! eek So, B**e Me! :mad: Leave me alone....."Never Mind!" frown
G.L. Grumpy's
Old Iron Ranch
#42173 12/23/2001 10:33 AM
Keep it stock and drive it slow per Frank McMullen keeping the Important ones going slow! grin grin
Or change the rear gears and still drive slow to keep the important ones going slow!
grin grin
#42174 12/23/2001 3:40 PM
Anonymous
Unregistered
Anonymous
Unregistered
#42175 12/23/2001 3:48 PM
#42176 12/23/2001 3:57 PM
Anonymous
Unregistered
Anonymous
Unregistered
#42177 12/23/2001 4:09 PM
Anonymous
Unregistered
Anonymous
Unregistered
#42178 12/23/2001 4:55 PM
#42179 12/23/2001 5:02 PM
Anonymous
Unregistered
Anonymous
Unregistered
#42180 12/23/2001 5:29 PM
#42181 12/23/2001 5:41 PM
Anonymous
Unregistered
Anonymous
Unregistered
oh oh!!!! he he
#42182 12/23/2001 5:55 PM
Looks like you lost this one Phat!!! smile
Attitude - The difference between an adventure and an ordeal!
Deja Moo - The feeling you've heard this bull**** before!
'63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red'
'69 or'70 or ? Mantaray DuneBuggy
#42183 12/23/2001 6:11 PM
This post needs to go out with a bang [img]http://www.tlio.demon.co.uk/26$3$64.gif[/img]
#42184 12/23/2001 6:11 PM
Anonymous
Unregistered
Anonymous
Unregistered
Big time !! eek
#42185 12/23/2001 10:42 PM
Hey Phat, Nice to see you back. Let me know what you used on those Fentons to get them looking so nice. Thanks.,
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
