4 members (Dennys28, TexasA&M48Truck, Hotrod Lincoln, spanky), 62 guests, and 2 robots.
Topics128,022
Posts1,055,381
Members48,422
#421795 06/10/2008 11:59 AM
T56 article I noticed people were installing T5's in there trucks and wondering if anyone has tried installing a T6. The idea of it interests me
The 38 Special #421834 06/10/2008 4:12 PM
I believe the reason more people aren't using the T56 is because the shifter location is so far back... about 23 inches from the bellhousing. Take the stock 4 speed with the shift tower coming up at 4.5 inches from the bellhousing, and you can imagine the problem with seat clearance. The T5s with the S10 tailhousings shift a little bit further forward than the other T5 transmissions making them an ideal swap in an older truck with a small cab.
