7 members (crenwelge, JW51, Lostbuthaulinass, Hugh63c10, Gray_Ghost, 1955 1 Series, greenie-reddy),
161
Mod | | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | does anybody have an estimate on what kind of gas mileage my 72 GMC 7500 6X6 wrecker would get pulling a 28 foot semi trailer. it has the 401M 10 speed overdrive transmission and 7.10 axle ratio. also has a edlbrock 600 cfm carb.
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I believe my '62 GMC 6500 with a 478 V-6 got about 7 or 8. The overdrive you have will help, but if you can get 8 that would be pretty good in my opinion.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think 7 or 8 is wishful thinking. 5 is more realistic. If the 28 footer is a dry box 13'6" high expect about 4. Those old gas burners weren't very fuel efficient. I ran them until the late 60's. I run all diesels now. | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | 3.5 - 4 is what I'd expect. That's what an old glass truck I once had got with a 427. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | A thought for ya, I had a '65 3/4-ton with a 327, TH350, & 5.30ish gears out back. When I got it the intake was all stock for that motor and it got horrible milage, somewhere around 5 or so. However, I broke down and bought a 650CFM 2-bbl Holley Pro-Jection TBI system and a Edelbrock performer intake. Between that, shorty headers with dual turbo mufflers & a swapped in HEI ignition, I went up to approx 10-15 MPG and could tweak it to run cleaner than a new car, plus had the ability to adjust on the fly (I mounted the brain in the glove-box. Before she died on me (head gasket leak, siezed piston, busted rod, oh darn,...) I was pulling a trailer and fully loaded bed and there was no real difference in fuel consumption. I cant say what sort of performance gain YOU would get, but it's a thought.
I know it's heresy, puttin something so new fangled & confusing to work on on an old bolt, but then I'm one to be controversial. :P However, if you're lookin to get the most bang for your buck,... It's an idea anyway. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | i haven't seen any intake manifolds for the V6 but i do have rebuilt 427 tall deck that i could put in and run fuel injection with | | |
