4 members (Guitplayer, Hotrod Lincoln, Bill Hanlon, Gdads51), 125 guests, and 1 robot.
Topics128,109
Posts1,056,271
Members48,439
#42062 05/26/2005 5:10 AM
Stamped serial number next to distributor is
F1019CCK. I believe it came out of a 68 or 69 K-20 PU. Thanks in advance, Garry K
Garry K in Pac Nor West
1948 Chevy PU 235 SM420 4 spd
1932 **** B pu
1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
#42063 05/26/2005 6:47 PM
The CCK is popular, 70,74, and 78
http://no25.homestead.com/page3a.html#1970
#42064 05/27/2005 3:15 AM
You can also check the casting number and date codes. On the distributor side, casting number should be just aft of center. Large, raised numbers. Look it up at www.inliners.org . Aft of that will be the date code. should be a letter followed by two or three digits. Letter is the month, A=Jan & on. Then is the day of the month, one or two digits, followed by the last digit of the year. So G128 would be July 12 of 68 or 78. C 35 would be March 3 of 65,75 or 85. Usually the casting number will narrow it down to figure out which year the casting was made.
Fred
52 3600
69 C-10
