8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian), 149 guests, and 3 robots.
Topics128,043
Posts1,055,524
Members48,424
#42055 10/04/2003 5:08 PM
k10
Offline
How do I test the temp sensor. I have the brass type at the back of the head near firewall. It's electrical to the guage. Master parts book and service manuals do not list a P/N.
Right now the guage does not register anything for quite a while during idling and then pegs out during driving. :rolleyes:
#42056 10/05/2003 10:49 AM
k10
Offline
Is this so hard it's a stumper? Or it's so obviously simple, it's stupid?
#42057 10/05/2003 12:58 PM
The sender should be heated in a pan of water. The reading will be in ohms but I am not sure of the range of readings on your sensor.
Peter, remove the sensor and swing it around so that you can take a pot of boiling water out and place it on the fender and drop the guage in it and then look in the cab and see.
The earlier and later are gas (?) filled originally and I think now they use MEK (methyl ethyl ketone) to fill them. Your "CC" would have indeed used an electric guage, GMC part number 1512200.
Take a heater rheostat and hook it up to the wire and then try dialing it up and down and see if you can get the guage to move some. That will isolate the guage portion and let you know if it's the sender or the guage.
