| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42055 10/04/2003 5:08 PM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | How do I test the temp sensor. I have the brass type at the back of the head near firewall. It's electrical to the guage. Master parts book and service manuals do not list a P/N. Right now the guage does not register anything for quite a while during idling and then pegs out during driving. :rolleyes: | | |
#42056 10/05/2003 10:49 AM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Is this so hard it's a stumper? Or it's so obviously simple, it's stupid? | | |
#42057 10/05/2003 12:58 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The sender should be heated in a pan of water. The reading will be in ohms but I am not sure of the range of readings on your sensor.
#42058 10/05/2003 3:05 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Peter, remove the sensor and swing it around so that you can take a pot of boiling water out and place it on the fender and drop the guage in it and then look in the cab and see.
The earlier and later are gas (?) filled originally and I think now they use MEK (methyl ethyl ketone) to fill them. Your "CC" would have indeed used an electric guage, GMC part number 1512200.
Take a heater rheostat and hook it up to the wire and then try dialing it up and down and see if you can get the guage to move some. That will isolate the guage portion and let you know if it's the sender or the guage. | | |
