The finishing process and all of its confusion.
The time was October of 1950; the place was the Chevrolet assembly Plate #21, Janesville, Wisconsin. The cab was in a thin coat of red oxide primer and the rest of it’s sheet metal was in a thin coat of black electro coat. And then the Mariner Blue enamel was applied, baked and out the door she went. That was the finish that lasted for 58 years.
So flash ahead to this past week here in Sandwich, IL and the attempt to erase those 58 years worth of use and abuse to her bodywork begins. Not by a real body man but by a do-it-yourselfer cuz that’s all I can afford. I’ve got the tools I need, I’ve got most of the knowledge of how it’s supposed to be done but I don’t have the experience in metal bumping/dinging. So I’ve been working every day on a couple of scrap fenders for the past couple of weeks to try and develop those skills. And it’s coming along sloooooowly.
I started on the real thing a couple of days ago and when it had all the layers of paint on it, it didn’t look all that bad. Once I got it down to bare metal, blued up and blocked all of the highs and low stood out like a sore thumb. Instead of a dozen or so dings that I thought I had felt, there appears to be an entire fender full of dings. The term I heard someone use once was, “it looks like a bag of Walnuts.” So I’ve got about half of the fender fairly smooth and back into shape but I’ve got a long way to go if I’m going to do this with an absolute minimum of filler or loss of metal by filing. This shot might show some of the challenge ahead of me.
http://rides.webshots.com/photo/2786342640098611668QfaKNm Once I get the fender straight the next step I’m planning is the inevitable application of a “little” Rage, the plastic kind that is. Since the metal wasn’t treated with a metal conditioner when new then I see no reason for it now. The entire surface will be sanded and primed with PPG DP90. Next step will be a high build primer, PPG K36 Prima which I will block down in hopes that I can arrive at some degree of proper form prior to application of the Delstar Mariner Blue.
Seems like of the 87 people that I have discussed the finishing with, I have 87 different opinions as to how they would approach the task. Some say fill over primer, some say acid etch primer is a must, some say condition but don't acid etch, then there is the problem with filler over conditioner not recomended by some and on and on. So how does my simple straight forward plan sound to you experienced PPG’ers and ya suppose I can get opinion 88??
Denny Graham
Sandwich, IL
