8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible), 99 guests, and 7 robots.
Topics128,264
Posts1,058,358
Members48,485
#420324 06/05/2008 11:53 PM
I determined that the starter button is worn and not making a good contact
The local parts store can get the pre 57 button next day but the 57-60 button is 2-3 weeks
Will the early button work okay?
In think it might be missing the wire to the coil for easier starting.
Should I try to find the proper one?
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
The earlier "button" will work OK but the wire to the coil aids in starting. Can you order from Advance Auto and easily arrange shipping to Canada?
thanks
I"ll try NAPA tomorrow
Regards,
Lindsay
It could be your linkage is worn and sloppy and not depressing the button all the way.
The brass tab inside has a noticeable wear groove of about 3/8" of an inch.
Regards,
Lindsay
