0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | I realy have 2 questions unrelated. First question I have a 51 Chevy 1/2 ton three speed on the column and I usally grind second a little bit 90% of the time. First and Third and reverse are fine. Is there a linkage problem or is it a normal thing that I must live with? Second question I have two rims that don't have clips to hold my Chevroltet Moons. I bought the clips and put them on and I still can't get those moons on. Any one ever done this job and my clips are smaller than the clips on the front wheels. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | TPB,
Can't help you on the clips, and maybe not the transmission either, but my bet is you have a bad 2nd gear synchronizer.
Stuart | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | TPB, Chevy 3 speeds have notoriously weak synchros, pretty good chance that's your problem. | | | | | Joined: May 2007 Posts: 46 New Guy | | New Guy Joined: May 2007 Posts: 46 | Try double clutching when you go into second. And there is no need to rev the engine when you do. A little practice and you should get it......Find a safe place to practice. When sitting still with the motor running in first gear slowly release the clutch pedal. When you feel the clutch start to engage stop and push it back in a little bit. That is Approx how far you need to depress the clutch to shift while moving. By letting the peddle come back to the top between shifts you match the speed of the gears in the tranny to the speed of the road and engine. This should allow a quiet shift......Hope this helps.
It's easier to get older than it is to get wiser.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'm sending this to engine and driveline. You may re-post the wheel question on general truck talk. | | |
