2 members (78buckshot, 1 invisible),
390
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42020 03/22/2005 1:08 PM | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | I installed a TCI Mustang II front end two years ago finally getting road worthy but I find the shocks that they provided not sized correctly. The rebound only gives me about an inch of travel. with the chassis on stands there is no way I can get the lower shock bolt in with out jacking up the wheel. Anyone else had the problem? Size solution? I will jack up today and pull a shock set at road height and measure rough measure was 11" at road height, but I need to get more accurate from center of lower bolt to bottom of shock tower -5/8". I need 5-6" of travel, which will put the compressed height aroumd 8". Zeke I pulled shock, the compressed height should be 8 1/2" and the extended 13 1/2" with the ride height at about 11 1/4",this is 11 3/4" shock tower to bottom bolt center with 5/8" deducted for top grommet, shock supplied by TCI only has 12" extended. Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
