0 members (), 159 guests, and 2 robots.
Topics128,260
Posts1,058,342
Members48,485
#420052 06/05/2008 2:36 AM
I received my new patch panels; floor, rocker panels, inner corners, but I'm having trouble finding weld-thru primmer. Anyone with any suggestions on local stores?
I get mine from my local napa store. But do you expect a lot of salt and bad weather down there? If you can get behind the panel after it is installed just prime with etching primer and treat as normal.
It's easier to get older than it is to get wiser.
Here is the link to dupicolor website.
http://www.duplicolor.com/products/pro_primers.html
Have fun with it..
I have used it before in a profesional auto restoration shop. Some places it is a good idea, but it can make a mess with the MIG welder popping and spitting. If you first scrape the visible stuff out of a plug weld hole it helps some.
It's a nightmare with the TIG welder, you better enjoy grinding tungsten.
Some brands are worse than others when it comes to welding over it, and the harder ones to weld around are probably the better at not rusting. The two I used were made by Wurth http://www.wurthusa.com/project/en/leftnavi/catalog/product.php?path=04.0241.jpg and 3M http://multimedia.mmm.com/mws/mediawebserver.dyn?6666660Zjcf6lVs6EVs66SMj3COrrrrQ-
The Wurth brand was the most difficult, before to long the spray can had a new paper label, it read "Spray on weld contaminator, best when used liberally"
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #420151 06/05/2008 1:11 PM
There's been a lot written about the toxic fumes so I don't use it..Probably some threads here or at Hotrodders. Be careful.
Keith
