1 members (Peggy M), 304 guests, and 4 robots.
Topics128,159
Posts1,057,033
Members48,460
I need to check the shoes and drums on my 65 C20. I pulled a rear wheel off last weekend, but I'm not too familiar with the Eaton 3/4 ton axle yet and didn't quite see an easy way to get the drum off. I was running out of sunlight so I put everything back together. Do I need to pull the axle and hub to get the drum off? Or did I miss something obvious?
To old to change, to young to quit.
There should be some countersunk screws holding the drum to the hub. Providing that the screws and drums are not too rusted up the drums should slide off. You may also have to back off on the brake adjuster.
Fred
