7 members (dt235sd, Cosmo, jeffreyguy, Otto Skorzeny, Charles in CA, LAROKE, Wally / Montana),
137
Mod | | | Forums66 Topics128,107 Posts1,056,221 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | I bought a used set of gauges. Is there a faster way to reset the odometer to 00000? The drill method is taking a while. | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | pop it open and do it by hand . but i remeber somepeople saying turning to 000000 will jam it , but have a 1 at the end is fine . | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not know about earlier gauges, but the tumbler (? mileage wheels) in the 1954/55 gauge comes out easily, can be reset, and can be set to zero, and can be returned to the speedometer assembly, and works fine afterwards (the 47-54 odometer might be a different matter). | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I don't remember how long it took but when I worked for the Ford dealer back in the year of dirt, they had me hook up a 1/2 drill and run the mileage forward on a 1963 Cobra they drove from California and expected to sell. I only did the hookup and someone else pulled it off when the mileage got down to under 10 miles.
~Jim
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I redid my odometer a few moons ago and never did it prior. I kept a photo journal here that may give you some ideas or help in some way. It was quite easy for someone with all thumbs. Have fun and good luck. Dan | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Anyone that has tried the drill method will realize that the drill will wear out before you get any milage off. The speedo cable turns faster than the drill and look how long it took to get those miles on, | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It will work but take a few hours (all day). I've seen it done.
~Jim
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I would recommend NOT trying to take the odometer wheel assembly apart and attempting to rotate the individual wheels to get it back to zero. I've seen very few done by a novice, that didn't have a misalignment of the digits, or didn't function at all.
On my 54, I simply used the decal kit from one of the normal vendors....marked a line across the numbers that were in front of the little window...carefully removed the whole little wheel assembly intact (You may have to loosen the speedo face....see caution below) and apply the decals on the mark, wiping down the drum assembly beforehand with some alcohol. It's going on 2 years since I applied the decals....they look as good as the day they were installed.
The kit also includes the gauge face decals which are a snap to apply to refreshen the gauge appearance. The trick is to use a couple drops of water/soap solution on the old gauge face. Just enough to wet it so you can move the decal around to position it correctly under the needles. When you've got it positioned correctly, use a q-tip to squeege out the water and any bubbles of air. NOTE: a couple drops of dish soap in a glass of water is sufficient.
When working with the speedo be very careful with the main needle....it will break off with just a minimum of force.
Dave | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Does anyone know where I can send my speedometer out to get rebuilt? I am restoring my fathers 1957 Chevy P/U he bought new. I am trying to use all the orginal parts. Thanks! Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | BigChevy! Thanks sooo much! I just talked to Julia and I am sending the unit down to Riverside, Ca. and they are going to repair and replace all the guts! I will let everyone now how it goes! Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | |
