2 members (Otto Skorzeny, 5 Window 9434), 130 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#418527 05/31/2008 3:42 PM
If I remove the 10 bolts on a '53 Chev 3/4ton rear end cover plate to drain the gear lube, what's going to come out? I reviewed several past posts from years back and saw a mention of the entire innerds coming out, but it wasn't clear what was taken loose to make that happen. All I want to do is remove the axles, take off the cover plate and clean the inside out to get rid of all the sand I mentioned in a previous post.
Rick #418535 05/31/2008 4:08 PM
There are not going to be any loose parts in your differential; unless something is broken, just 50 year old GO-90.
Just some very smelly hypoid oil! eek P.S Wear latex gloves! It stinks! big_eek
Jock.
P.S Gear oil can also cause dermatitus.And Tiny's right, nitrile gloves are better. I use them in my own job DUH!
More pix on Flickr.
Ex Hall Monitor
Ex Hall Monitor
Good advise except make them nitrile gloves. They're more durable than latex.
