| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Guys, Question 1 I am about to rehang my doors on the 49 Burb after new glass, felt channels, etc. The doors had no door weatherstripping when I bought it and doesn't appear to have been removed by the PO. Is this normal for Burbs or should I install a weatherstrip?
Question 2 I have to replace the upper springs in the door hinge. Can someone give me any helpful hints on the do's and don'ts of the process. This may belong over in the Door Section but wanted to ask here first. Thanks
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Question 1: All side doors on 47-55 trucks had a seal (weatherstripping). http://www.classicparts.com/1947-66--Door-Rubber-Seals-Glue-On/productinfo/03%2D011/ Jim Carter sells rear door seals (clamshell doors, if you have the original doors for your year) but they were a terrible fit when I bought them several years ago. Steele Rubber had the correct rear door seals. Question 2: These might be a little helpful. http://www.chevytrucks.org/tech/doorsprg.htmhttp://www.classictruckshop.com/door_hinge.php | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
