2 members (Peggy M, 1 invisible),
168
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 13 New Guy | | New Guy Joined: Jul 2005 Posts: 13 | I'd appreciate advice on the best way to get a good seal when installing a new cork valve cover seal on a 216. I've done it several times over the years, but never with full satisfaction.
Bob Acland | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bob,
Here is my recipe. Clean the cover and flange very well. Set the flange on a bench corner and hammer the screw hole dimples flat as well as flange.
Apply your favorite spray gasket adhesive to the flange AND one side of the cork gasket. Let them dry and stick them together.
I have always put sealer on both sides, but the general consensus seems to be that the side towards the engine is fine as is.
Clean the head mating surface well and install the valve cover. As I read over your post I see it's a 216 so you have no screw holes to hammer the dimples out of...my bad!
When you cinch the two bolts down, do it with much reservation. They only need to be snug. Too tight and the valve cover get sprung and could leak.
Making sure the flange is clean and flat is the key. Although there is a cork gasket involved, this could almost be looked at as a mechanical seal. Good luck.
Stuart | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Yup, keep it clean and don't overtighten. Always keep in mind that the old Chevy six that doesn't leak oil somewhere doesn't have oil in it.
