| | | Forums66 Topics128,185 Posts1,057,275 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I noticed my oak wood planks do not have the cross sill holes drilled out. Can anyone give me a procedure to do this right the first time? They need an offset counter sunk hole for the washer as well right? Oh, and I'm not even sure if they are the correct length or need to be trimmed. What is the length for a 55 short bed?
Thanks. Michael
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the only holes you need are for the mounting bolts thru to the frame, the ones with the washers, best you mark from underneath with your bed assembly loosely together .... and that countersink needs to be offset from the bolt hole if you have the correct washers .... the bolts thru the skids go between the boards .... measure the length with the sheet metal together, you don't want them a bit short, measure twice, cut once!
Bill | | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | To add to what Red said . . . To counter sink the off-set washer, use a Forsner Bit (Porter and Cable make them) and drill the bolt hole second. Or else the forsner bit will dance around your boards. HC | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | | | |
