| | | Forums66 Topics128,080 Posts1,055,946 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 23 Apprentice | | Apprentice Joined: Apr 2008 Posts: 23 | Is there a way to adapt a 2 barrell carb to a single barrell intake on a 66 292? The carb is bad but I have a good 2 barrell'
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There are adapters available. Google speedshops. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The two-barrel through the 2->1 adapter will not work nearly so well as the one-barrel. However, if you don't mind the loss of fuel economy and the loss of power, the conversion might buy you a little time to fix your existing one barrel or replace it.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | What if one were to mill the intake off flush with the runners and weld a 2bbl mounting flange sideways? Could a 2GC be used to it's full potential on inlines? Is there a formula that describes how tall the carb flange should be?
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Curt - possibly, it would depend on the shape of the plenum. If the plenum is of sufficient size that the air/fuel from both barrels of the carburetor could enter the plenum with no restriction from the walls of the plenum, then the design should work. The air/fuel entering the plenum from the carburetor should NOT be restricted.
As to the height of the carb flange (or the distance from the plenum to the throttle butterfly): the optimal distance will vary based on the use of the engine. An engine for a truck (good idle, good low end torque) would have the carb flange very close to the plenum. More power at the high end of the RPM range (AT THE EXPENSE OF LOW END TORQUE!) may be obtained by raising the carburetor (eg. tunnel ram intakes). Raising the throttle butterfly in effect increases the volume of the plenum, and helps minimize individual cylinder pulsing.
