6 members (Wickedbass, jkreiner, mvigo, Charles in CA, Rusted Nut, 1 invisible), 75 guests, and 3 robots.
Topics128,074
Posts1,055,913
Members48,429
#416678 05/26/2008 1:29 AM
GMONIZ,THE ANSWER TO ALL YOUR QUESTIONS IS YES,IT ONLY HAS THE POPING SOUND WHEN I INGAGE THE TRANS,IT STAYS IN THE GEARS AND DOES NOT COME OUT,NO BINDING,NO HOWLING AND BY THE WAY,I DONT KNOW HOW TO GREASE THE U-JOINTS BECAUSE THEY ARE IN THIS INCLOSED TUBE?AGAIN THE DRIVERS SIDE MOVES FREELY,BUT THE PASSINGER SIDE WILL NOT MOVE BY HAND TURNING THE WHEEL.THANK YOU..LET ME REPEAT WHAT IS HAPPING TO THE PANEL,WHEN I PUT HER IN GEAR AND TAKE OFF IT HAS THIS POPING SOUND,I THEN PUT HER ON SHOP JACKS AND THEN PUT INTO 1ST GEAR AND LET OUT THE CLUCH,IT STARTED THE WHEEL ON THE DRIVERS SIDE TO MOVE BUT THE PASSINGER SIDE DID NOT GO,I STOPPED THE ENGINE AND THEN TRYED TO TURN THE WHEEL FORWARD BY HAND,IT WOULD NOT MOVE,NOW WHEN THE PANEL IS ON THE GROUND AND OFF THE FLOOR JACKS THE WHEEL DOES MOVE FORWARD,BUT I HEAR THE POPING SOUND,IAM AT A LOST..THANKS,BOB
gigi #416862 05/26/2008 5:40 PM
does any one have a answer for me .????
gigi #416868 05/26/2008 6:03 PM
gigi,
My first guess would be a broken brake component on the passenger side that is binding it up. Pull it apart and have a look, you might find a delaminated brake lining jammed where it shouldn't be.
Stuart
atomarc #417406 05/28/2008 2:27 AM
gabster,thank you,it was the emergecy brake gable binding up,i fixed it and now it spins freely,now to find out how to grease the u-joint,i know that i can find it..<i hope>lol
