| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41729 05/23/2005 6:23 PM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Hi, My brothers 50 Chev 1/2 ton needs an new motor. His 216 has bit the big one. I found a complete 216 engine and transmission out of a 49 Chev car. It has a split manifold. Would this engine fit into the 50 Chev truck? Thanks.
kskt4 | | |
#41730 05/23/2005 6:46 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | KSKT4, It shouldn't be any problem at all to swap out those two motors. They should be virtually the exact same. The only issue you might have is bell-housings. However, as long as you use the bell-housing and transmission from the truck, you should be okay. Good Luck. | | |
#41731 05/24/2005 12:07 AM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Thanks Jed, I will call my brother and let him know.
kskt4 | | |
