| | | Forums66 Topics128,210 Posts1,057,459 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41710 03/18/2003 9:14 PM | Joined: Mar 2003 Posts: 49 Member | | Member Joined: Mar 2003 Posts: 49 | I would like to know if anyone has a good way to mount a 292 in a 59 chevy panel. I was planning on getting a v8 crossmember mount but I noticed the side mounts on the 292 are staggered unlike the 230 or 250.Would the crossmember mount work if I used a plate made from steel to go from the block back to where the crossmember mount is. This would cover the place where the fuel pump is located but if this would work I could just run an electric fuel pump.If you have installed a 292 please give me some feedback. Also I plan to bolt it up to a th400 tranny and 3.07 rear out of a 72 chevy truck. Will this get better gas milage over a 350 with the same tranny and rear combo? | | |
#41711 03/18/2003 10:35 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I'm not sure if that would work - GM moved that motor mount for a reason, the 292 was cracking motor mounts, the block, or something. I think there is more info on this over at Inliners.org . | | |
