1 members (baldeagle), 40 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#417026 05/27/2008 3:23 AM
Y
Y Offline
My truck has been converted to 12 volts. Every thing I read says the ammeter does not have to be fiddled with to work, yet mine does not. Is this info correct?
Tempe, AZ
Bill S.
Tempe, AZ
Bill,
That is correct info...no fiddling needed. The crux of the issue is, was it converted properly. If it was done wrong, your ammeter might not function the way it was intended to work.
Did your conversion involve a alternator, or did someone install a 12 generator?
Stuart
Y
Y Offline
A 12 volt generator that I just had rebuilt and know functions correctly. However the ammeter has never worked.
Tempe, AZ
Bill S.
Tempe, AZ
Bill,
If you had the 12 volt generator installed along with a new 12 volt voltage regulator and the charging systems works, but doesn't register a charge (or discharge) on the ammeter, then I would surmise that the ammeter is broken
The generator charges the battery THROUGH the ammeter. If your system is staying charged, then it's a mechanical failure of the little movement inside the ammeter. Does this sound right.
Stuart
Riding in the Passing Lane
Sounds right to me. Check to see if the meter is wired up. Sometimes someone will bypass it if something is not working right. It should have a heavy gauge wire on each term.
1972 Chevy c10 Cheyenne Super
