2 members (3B, baldeagle),
102
Mod | | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | Can I check the timing on my 305 without having the engine running? I can't get it to run, and I have already ruled out the carburator. When I try to start it, it will sputter, and backfire out of the carb. Sometimes when it quits it makes a hissing sound out of the carb and exaust gets blown out. So, I am guessing maybe the valve timing is off. How would I go about using a timing light?
Also, I checked my distributor today. I took the cap off and looked at it as I turned the flywheel. It doesnt immediatly start turning with the crank. Could it be caused by a stretched timing chain? Or could there be wear on the drive gears for it? Thanks guys.
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
| | | | | Joined: Oct 2002 Posts: 28 Junior Member | | Junior Member Joined: Oct 2002 Posts: 28 | Uh. No. If it ain't runnin the timing light is not gonna do anything. give that idea up. but ballpark spark timing is easy if you just compare flywheel and distributor rotor positions. (eye ball should get it close enough to run. Then do it by ear from there.) But if you've got a lot of lash between crank and distributor rotor then you're not gonna be able to fix it with just timing. I'd go ahead and pull the valve cover. Then you should be able to check valve timing with cranking flywhell forward and again turning backwards. If the same valve event isn't at the same place both ways you can guess the timing chain has slack.
But, I'm no pro. see if you get beter ideas in here too. | | | | | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | There seems to be a lot of movement in the crank before any of the valves start to move. Guess it is time to pull the timing cover.  by the by, where can I get a new timing chain for the 305?
Jonathan S. Keffer
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Kanter auto parts will have them.
