1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 23 Apprentice | | Apprentice Joined: Apr 2008 Posts: 23 | Where do I find 1 piece wheels (used) to replace the split wheels on my 66 C-60. Wheel size is 9.00X20. | | | | | Joined: May 2008 Posts: 114 Shop Shark | | Shop Shark Joined: May 2008 Posts: 114 | Go to any tire store that sells large truck tires and inquire. Many stores will know someone that may have used rims available for a reasonable price. You will end up having to buy new or used tubeless tires for these rims, so the tire store will be in your wallet too. Good used steel rims should run you $30 to $50 apiece. Good Luck, JAMES | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Read this Tech Tip first: http://www.stovebolt.com/techtips/wheels/You probably have 6 lug stud centered Budd wheels, and you can easily find used 22.5" wheels in junk yards, or buy new ones. Grigg | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Here is my 64 http://inlinethumb52.webshots.com/9779/2620335470096773078S425x425Q85.jpgIt has 10 Hole, 8 3/4" Bolt Circle, 6.25" Bore Hub-piloted wheels they are 22.5 X 6.75 Accuride P/N 28160 found on page 12 of their catolog. If you have the 6 Hole, 8 3/4" Bolt Circle, 6.5 Bore Stud-pioted The same 22.5 X 6.75 wheels to fit are on page 18 P/N 28157 for tires I used 9.00 X 22.5s recaps on the rear with a waste hauler lug and new ribbed front end Toyos
| | | | | Joined: Jan 2008 Posts: 33 Apprentice | | Apprentice Joined: Jan 2008 Posts: 33 | Just curious, about how much did the rims cost from Accuride?
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I got it all at Les Schwab tire for just under $3000 wheels tires mounting with the stems and Equal, it is an automatic balancing agent that goes in the tire and works great.
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | The truck was a good driver with the 10.00 X 20s but the difference with the new tires and wheels was nothing but incredible it now drives like a new truck and picked up about 1 and a 1/2 MPG. | | |
