3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#41647 11/09/2003 9:07 AM
I just removed the pinion yoke to change the seal and I am wondering what amount of torque to tighten the nut back? The rear-end is a '66 12 bolt.
Be Happy and Live a Good life filled with Love and Happiness.
#41648 11/09/2003 4:41 PM
Sounds like you didn't read the shop manual before you disassembled. You were supposed to mark the nut and flange location and measure the preload, then install with those specs. Now you know for the next one you do.
Torque on the pinion nut is about 180 ft-lb, but you can't go there again without replacing the crush sleeve. Preload on the used bearing is 5-15 inch-lb. Install nut and tighten to remove end play. alternate between tightening and checking pre-load torque, until pre-load value is reached.
Fred
52 3600
69 C-10
