| | | Forums66 Topics128,114 Posts1,056,605 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | I HAVE AN AWFUL SMELL OF GAS IN MY CAB. THERE IS NO GAS LEAKING ONTO THE FLOOR OR UNDER THE TRUCK. I HAVE NOT REMOVED THE SEAT AT THIS POINT. I AM JUST WONDERING IF THERE IS A SOMETHING I SHOULD BE LOOKING FOR FIRST BEFORE I REMOVE THE TANK. ALSO MY FLASHERS DON'T FLASH AND ALL THE LIGHTS WORK. WHERE IS THE FLASHER? | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | (all caps = yelling here)Someone will come along shortly to address your problem... Nice to meet you. | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | TPB, Your gas fumes sound like you have dry rotted fill hose or overfill hose. The rubber hose between the outside fill pipe to the tank. Or the gasket on the sending unit may be cracked.
I'm not sure what to tell you about your flashers. The flasher should be under the dash around the steering column. I depends where the po installed it. Good luck! | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | TPB- On mine the gasket on the sending unit was non-existant & the whole cab reeked.
My flashers are on the old after-market turn signal handle. | | | | | Joined: Mar 2008 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 61 | The flasher could be anywhere since whoever installed the turn signal had that option. Do a serch on turn signal wiring and then try to trace wires from there. Bill Tempe, AZ
Bill S. Tempe, AZ
| | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | It seems that when the gas gets down a bit the smell in the cab stops. I don't know if that pinpoints the provlem any better. | | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | It could still be the things that were mentioned. When the tank is full, the gas will splash up and leak around that bad gasket or fill hose. After the level goes down, the gas can no longer reach those areas, hence no more smell. | | |
