0 members (),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | My build of the 1954 261 engine has been on the back burner for some time now. I have recently started working on it again.We started to install the oil pump,and it is different than my original.The oil pick up tube thread hole is smaller on the new one.The position of the lines are different.Being a holiday weekend,i can't contact the machine shop i used for machine work and parts.Here are the details,what do i have.I'm also providing pictures,any help will be greatly appreciated. new pump melling # m-45 is shorter than original,thread holes are smaller,location of lines are different. original gm pump # 37023 65 GM 20 stamped on pump housing. Is taller than replacement. 261 oil pumps 261 oil pumps pic #2 melling 261 oil pump original 261 oil pump Thanks,Tim
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2004 Posts: 45 New Guy | | New Guy Joined: May 2004 Posts: 45 | Looks like they ordered a pump body for the wrong year. I think '55 and up were different. There were a few changes through the years for pick ups and oil pan baffles too.
Ed Fallon In seemlingily endless process of restoring a stock 1953 chev 3100 pickup.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The oil pump from a 1954 235 looks similar to the original.I'm not sure if they are the same. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2004 Posts: 45 New Guy | | New Guy Joined: May 2004 Posts: 45 | The 235 and 261 truck engines share the same oil pump between the same years.
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | I have two 1954 261 engines. One of them has a GMC oil pump, so that is not much help for this problem. The pump for my other one is similar to the the "original" in bowtietm's images. I'm pretty sure that the Melling is for a 55.2 or later 235-261, as the manuals and parts books show that the 1954-55.1 have the pressure regulator in the main pump body and the later pumps have the regulator in the cover. Check the Chevrolet Master parts catalog for the parts numbers. A 1954 (and probably a 1953 Powerglide) 235 pump should also fit your 1954 261.
Hoyt | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Ed and Hoyt,thanks for the information.I went to lmc today and purchased the right oil pump for my engine.My pump is listed as the 1954-1955 1st series pump and yes the 235 is the same pump. sealed power # 224-4142 has m-29 stamped on pump shaft housing. melling part # m-29 Here are a couple of pics of the new pump beside the original. 1954-1955 1st oil pump 1954-1955 1st m-29 oil pump I do have a question about the pickup tube>I will start a new post on it. Thank you for your help,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
