7 members (TUTS 59, Otto Skorzeny, Phak1, baldeagle, Hambone, dunfire, Rusty Heaps),
55
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 56 | How do you remove the old throttle and choke knobs from the metal stems. I want to put my old 1940 knobs on new cables. | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I don't know if you can remove them from the old cable, you can order some new ones that look pretty good frpm Jim Carter.
Ed | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Double posting is frowned on by the Mods. Check the answer I left you in the Paint and Body Shop forum.
| | | | | Joined: Feb 2006 Posts: 12 Apprentice | | Apprentice Joined: Feb 2006 Posts: 12 | how about removing the old broken knobs from window crank handles? what is the best way to do that? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It has been a while since my teardown but I believe there is a set screw for the door and window handles.
~Jim
| | | | | Joined: Oct 2007 Posts: 3 New Guy | | New Guy Joined: Oct 2007 Posts: 3 | I just drilled mine out from the back. Takes about 1 minute. Metal is very soft. | | |
