4 members (68ironhead, Wayne67vert, GRNHydra, Oswald), 131 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#416128 05/24/2008 2:08 AM
Apprentice
Apprentice
Where do I find 1 piece wheels (used) to replace the split wheels on my 66 C-60. Wheel size is 9.00X20.
ajhartle #416167 05/24/2008 4:14 AM
Go to any tire store that sells large truck tires and inquire. Many stores will know someone that may have used rims available for a reasonable price. You will end up having to buy new or used tubeless tires for these rims, so the tire store will be in your wallet too. Good used steel rims should run you $30 to $50 apiece. Good Luck, JAMES
1957 Chevrolet 6400 flatbed dump
Webshot pix
1942 Chevrolet 1 1/2 ton
1962 Chevrolet M80 tractor
oldiron57 #416170 05/24/2008 4:18 AM
Read this Tech Tip first:
http://www.stovebolt.com/techtips/wheels/
You probably have 6 lug stud centered Budd wheels, and you can easily find used 22.5" wheels in junk yards, or buy new ones.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #416286 05/24/2008 4:53 PM
Here is my 64 http://inlinethumb52.webshots.com/9779/2620335470096773078S425x425Q85.jpg
It has 10 Hole, 8 3/4" Bolt Circle, 6.25" Bore Hub-piloted wheels they are 22.5 X 6.75 Accuride P/N 28160 found on page 12 of their catolog.
If you have the 6 Hole, 8 3/4" Bolt Circle, 6.5 Bore Stud-pioted The same 22.5 X 6.75 wheels to fit are on page 18 P/N 28157
for tires I used 9.00 X 22.5s recaps on the rear with a waste hauler lug and new ribbed front end Toyos
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
HevyHauler #416617 05/25/2008 7:19 PM
Apprentice
Apprentice
Just curious, about how much did the rims cost from Accuride?
Adam Ogle #416646 05/25/2008 11:24 PM
I got it all at Les Schwab tire for just under $3000 wheels tires mounting with the stems and Equal, it is an automatic balancing agent that goes in the tire and works great.
user
HevyHauler #416648 05/25/2008 11:30 PM
The truck was a good driver with the 10.00 X 20s but the difference with the new tires and wheels was nothing but incredible it now drives like a new truck and picked up about 1 and a 1/2 MPG.
user
