2 members (jmoore, sron48), 68 guests, and 5 robots.
Topics128,187
Posts1,057,214
Members48,465
What is the stock width of the 53 chevy rear end. I want to compare it to the rear that was installed in a 53 I will be checking out this Friday that is not stock. Thanks Ed ke6bnl
1963 econoline, 50 f1 pu, maybe 53 chevy pu, 50 f3 pu, 70 chevy shortbed c10,
ed,
i dunno if this site has a '53 truck rearend listed, but you might wanna check out:
http://50chevy.freeservers.com/Suspension_Widths.html#Suspension
I AM IN THE PROCESS OF TAKING MINE OUT AND IT IS 55 1/2 WIDE +- A TINY BIT
I appreciate the information, can you tell me were you took the measurement. I would prefer to measure from the wheel monunt surface to wheel mounting surface. Thanks What are your plans after the rear is out?? Ed ke6bnl
The torque tube rear end in my 48 1/2 ton is 62 inches from wheel mounting flange to wheel mounting flange
1948 Chevy
5 window
"6" powered
I measured from backing plate to backing plate. And i am putting in a rear from a early 80's 4x4 chevy truck. And i got a transmission from a 70's chevy truck.
