| | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Does anyone know of a company who has the complete, and proper brake lines for a 46 Chevy 1.5 ton with 160" wheelbase?  Thanks Kevin Kevin
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Kevin
I haven't run across any vendor that supplies them as a kit. My guess is they are only made for the more popular half tons. You may have to buy the brake line bending/flaring tools and bend them yourself.
Are you still at the IGA in Winfield? I'm just up the road a few miles. I'd be interested in seeing your rig.
After reading your old posts, I happen to know of a 2ton that is pretty close that we could take pictures of the brake lines. I'll check my parts book to see if there is a diagram for the larger trucks.
| | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Kyle,
Good to hear from someone so close. I don't think I have met you before, but if I did I apologize. I do not work for IGA, but do work for Dierbergs out of Chesterfield. I would like to talk more, and would welcome you to come by and see my truck in pieces,as I have just started putting it back together.
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | There you go  | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i bent and flared the ones for my 46 2 ton it was easy. philip | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you have decent patterns then making your own is pretty simple. Or if you don't need originality then just make hem fit and look good. I have made a number of lines both in steel and stainless, three complete trucks worth and then some. It may take a few trys to get it right, don't be afraid to throw one away and start over, I have many times.
Grigg | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | if tour going to do your own line step up and buy decent tools for the job or you will only end up frustrated and waste time and money with failure. brake systems need to be done 110%,the extra 10% is for peace of mind.  | | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Thanks guys. I will let you know how they turn out.
Kevin Kevin
