1 members (TexasA&M48Truck),
67
Mod | | | Forums66 Topics128,082 Posts1,055,964 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 10 New Guy | | New Guy Joined: Jun 2007 Posts: 10 | I have a 49 just now restoring. Can you change out the single master cylinder to a dual master cylinder
tks dan in tx
Dan in TX
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes. It will require running some new brake lines, the front and rear will be separated from peach other. You might try a search on this site, that conversion has been covered extensively, you should be able to get the more specific info for setting up a dual M/C.
Bill Burmeister | | | | | Joined: Jun 2007 Posts: 10 New Guy | | New Guy Joined: Jun 2007 Posts: 10 | Hey tks I will se what I can find in archives
dan
Dan in TX
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Hey Dan - I'm in Hurst. I just installed a dual master cylinder on 37. I got the master cylinder from Master Power Brakes (MPC) and all of the fittings and lines from Stroud Auto Supply on Sylvania Avenue north of Airport Freeway. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jun 2007 Posts: 10 New Guy | | New Guy Joined: Jun 2007 Posts: 10 | Thanks Joe I just ordered a kit for my old cylinder and then got to thnking it would be better to upgrade.
Dan
Dan in TX
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | One of the better ideas to come out of Detroit many years ago.It is a lot safer brake system.Well worth the cost and labor of upgrading.I get a kick out of these guys who build a high performance streetrod,and still use the old single master cyl.setup,with drum brakes all around. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I don't think drum brakes all the way around are that bad. Many of the older vehicles don't weigh what today's vehicles weigh and don't need a fancy brake system - just a safe one. Square inches of shoes to drums will work great, if they work. To work their best, dual master cylinders are, as you say, one of the safer ideas to come out of Detroit in the years since many of our trucks have been built. With a dual master cylinder, it has to be a major, major problem if you can't stop. It's fine to get going down the road straight and fast, but you gotta be able to stop them, too! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | My point exactly.Youve gotta be able to stop in a safe manner. Although the single cyl. drum brake setup might be OK for and earlier model car,lets just say a 1955 Chevy.By the time you put in maybe a 383 stroker or perhaps a 454 big block and create a real bomb,the old brake setup is no longer up to par with the rest of the car.And even if you retain stock running gear a dual master cyl., is a good safety improvement.My 55 pickup has a 350 smallblock,700R4 trans. and is a heck of a lot faster than,a stock 1955 truck.It also has a power dual master cyl. with disc brakes up front,which sure help when it is time to stop.I feel that the extra dollars and work invovled with installing that setup was money and time well spent. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | It doesn't have to be a high performance hot rod to need a dual reservoir! I blew the right rear wheel cylinder in my stock '54 Buick Special. That meant there were NO hydraulic brakes, front or rear. And because the brake drum and shoes were now coated with DOT 3, the right rear drum did absolutely nothing when I stood on the emergency brake. A '54 Buick, traveling at 40mph with all the room in the world to the stop sign/intersection, will not stop on a single rear drum.
Every vehicle should be equipped with a dual reservoir, because doo-doo happens.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | How many different brackets are there and what type of master do most people use? I would like to keep it under the floor
