6 members (baldeagle, Lightholder's Dad, Christian, Wickedbass, NJC, Hotrod Lincoln), 63 guests, and 4 robots.
Topics128,017
Posts1,055,338
Members48,419
#415604 05/22/2008 5:55 PM
Ordered the Master cylinder from speedway today but have a question on installation. I presently have only a single reservoir. Going to upgrade to the split system but don't have the time to hook up the plumbing befor a show.
can I run the single line alone? Block off the other cylinder, or will that cause pressure on the dead side and decrease the braking?
gazim #415612 05/22/2008 6:20 PM
RT1 Offline
Good question, I don't know if that will work. You are going to proportioning valve if you have disc brakes up front. Not sure if you need one with drums...
RT1 #415614 05/22/2008 6:27 PM
No I am quite certain I don't need it with drums but I will split the system in a couple weeks, Just want to know if I can run it off the one line for a week.
RT1 #415615 05/22/2008 6:28 PM
wait till you get back from the show...............
that will be .99 cents please lol
Redryder pix
My Hotrod
RT1 #415616 05/22/2008 6:28 PM
I wish I had some knowledge that would help...
Anybody else out there?
Sabrina
'54 3100
just give in a try like you think it should work... trust your own abilities....................the worst thing that can happen is that it wont stop................then you will know that it dont work...
Redryder pix
My Hotrod
joker #415625 05/22/2008 6:48 PM
RT1 Offline
The purpose of a double system is to act as a fail-safe -- possible that you can just use one reservoir.
RT1 #415687 05/22/2008 10:25 PM
Riding in the Passing Lane
No you can,t run it that way. The pedal will be real low & it would probably damage the cyl. You could run them both with a tee.
1972 Chevy c10 Cheyenne Super
What you have in a split master is basically 2 masters in one. By blocking off one of the ports you create a dead end with no place for the pressure to go. Therefore, it would be logical that pressure would build up and you would not be able to apply any pressure to the brakes and you would not be able to stop......not good. frown Roy
It's easier to get older than it is to get wiser.
olcarguy #415995 05/23/2008 4:13 PM
Kinda what I figured too Roy, thanks all
