| | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 37 Junior Member | | Junior Member Joined: Sep 2003 Posts: 37 | My '59 3/4-ton 4-speed has a 235 and I just ran across a cheap '55 265 V8. Will this engine drop right in? | | | | | Joined: Sep 2003 Posts: 37 Junior Member | | Junior Member Joined: Sep 2003 Posts: 37 | Or would a 283 be the perfect fit? Or neither?  | | | | | | Anonymous Unregistered | | Anonymous Unregistered | It will if you have the pieces that were rivited to the front crossmember of the bent 8 trucks which positioned the front motor mounts further back than the sixes. The radiator also moves back although you could probably find or fabricate a fan shroud so you didn't have to move the radiator. | | |
