3 members (Millenimech, Shaffer's1950, Otto Skorzeny), 112 guests, and 2 robots.
Topics128,134
Posts1,056,403
Members48,441
#4155 09/26/2003 3:33 PM
Junior Member
Junior Member
My '59 3/4-ton 4-speed has a 235 and I just ran across a cheap '55 265 V8. Will this engine drop right in?
#4156 09/26/2003 3:44 PM
Junior Member
Junior Member
Or would a 283 be the perfect fit? Or neither? wink
#4157 09/26/2003 3:50 PM
Anonymous
Unregistered
Anonymous
Unregistered
It will if you have the pieces that were rivited to the front crossmember of the bent 8 trucks which positioned the front motor mounts further back than the sixes. The radiator also moves back although you could probably find or fabricate a fan shroud so you didn't have to move the radiator.
