2 members (Gdads51, 68ironhead), 174 guests, and 0 robots.
Topics128,110
Posts1,056,251
Members48,437
#4153 01/11/2002 6:40 PM
Phat, you posted this picture a few weeks back. How about a couple more. Specifically, under the alternator and front pass side of the engine. At first glance I thought you had a p/steering pump with remote reservoir under the alt, but the plumbing looks more like air. I see there is a dryer on the pass side.
[img]http://streetrod.50megs.com/images/235new1.jpg[/img]
I don't have the same engine and I'm not familiar with the mounting holes on your engine. I have the alt on bottom (stock) with steer/pump on top. If were to put an air/comp pump on the other side, it has to be really high or hang way off to the side. I picked up a camaro 250 bracket(s) which could be modified, but it's big, ugly, and you still can't get to the dist. It may not even work as is with an internal/coil HEI.
This is for a future project that will have a start date when I run across a factory suitcase that hasn't been brutalized.
[ 01-11-2002: Message edited by: Richard ]
'67 GMC 3/4 292 4spd
#4154 01/12/2002 9:43 PM
It's a Patrick's A/C & alt. kit. There is nothing available for pass. side installation that I'm aware of, You will have to fab your own stuff up for that. I did it on mine, pain in the butt, but it works.
