2 members (Peggy M, Ponchogl),
52
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 47 | Hi y'all,
I have a 58 TF 2 ton truck. Space is getting kinda tight around my yard and I was thinking about loading a 4000 pound tractor on the truck and then putting them in the shed. The tractor may set on the bed of the truck for several months. Do you think I would hurt the springs or doing any damage to the truck with that much weight sitting on it for long periods of time??
harrydale
Southeast missouri | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It'll be OK for a few months For a year or more consider jacking the truck frame up and supporting it to take the weight off the springs.
Grigg | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | try putting a block between the axle housing and frame before you load it. | | |
