0 members (),
135
Mod | | | Forums66 Topics128,275 Posts1,058,572 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41468 12/07/2003 6:11 AM | Joined: Nov 2003 Posts: 1 Junior Member | | Junior Member Joined: Nov 2003 Posts: 1 | HI OUT THERE! While putting my 235cid into the garage for the off-saeson, I noticed that the oil gauge showed zero. I took the valve cover down just to see that the oil pump is pumping oil up to the valves. Does this mean that the oilpressure is good and I just have a failure in the pressureline/oilgauge?? Any clues?? | | |
#41469 12/08/2003 3:55 AM | Joined: Dec 2003 Posts: 12 Member | | Member Joined: Dec 2003 Posts: 12 | i would check the linkages between the gauge and the oil pressure regulator it may be clogged or try running it for a while and it might kick back on some debris mave have gotten in the way and needs to be pushed out. Jose | | |
