Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 135 guests, and 4 robots.
Topics128,275
Posts1,058,572
Members48,492
#41468 12/07/2003 6:11 AM
Junior Member
Junior Member
HI OUT THERE! While putting my 235cid into the garage for the off-saeson, I noticed that the oil gauge showed zero. I took the valve cover down just to see that the oil pump is pumping oil up to the valves. Does this mean that the oilpressure is good and I just have a failure in the pressureline/oilgauge?? Any clues??
i would check the linkages between the gauge and the oil pressure regulator it may be clogged or try running it for a while and it might kick back on some debris mave have gotten in the way and needs to be pushed out. Jose
