2 members (Shade Baby, tclederman), 69 guests, and 3 robots.
Topics128,164
Posts1,056,966
Members48,458
did you have clearance problems with the trans? I am just mocking everything up but there seems to be a clearance problem. as you can see the trans is not even centered and it is rubbing. I may have to redrill the mounts in the booster bracket.
see the pics.
http://i11.photobucket.com/albums/a198/ahsum/booster2.jpg
http://i11.photobucket.com/albums/a198/ahsum/booster1.jpg
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
thats why i make my own brackets the booster can be mounted closer to the frame and use a 7 inch http://resurrectionvintageautoparts.webs.com/project54deluxecab.htm
1949 SUBURBAN
I am using a 7 inch booster, do you have any pics of your bracket? I looked on your webpage but could not get a good view.
thanks
If you have PS then you could easily use a hydrobooster, and it is much much smaller.
I really like my Hydroboosters, and won't ever use a vacuum booster if given a choice.
Pictures of my booster can be found in the axle swap folder on the picture link below, as well as some pictures of it once I swapped it to my diesel truck.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
what did you get the hydroboost setup from? looks sweet
