| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I am in the process of putting my 54 chassis back together. I was checking out the rear springs and discovered they are not the same. One main leaf is 20 thousands thicker than the other. And the thinner one has deep wear marks from the second leaf. I was going to clean them up and reuse them but now I will replace them.
Speedway carries posie super slider springs with a 3 inch drop. Has anyone used these? I have a mono leaf for the front, so the 3 inch drop should be close to what I am looking for. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Hey Lonnie; Someone was asking about Posie's springs awhile back and I don't think anyone ever responded. I guess no one has tried them yet (?)
I would think they would work fine, they've been building hot rod stuff for a long time and have a good reputation as far as I know. If you get them, give us a report o.k.? | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I personally haven't used them but I've heard good feedback. They have built in teflon buttons that make them quiet and smooth in use. My buddy fitted a set on his 46 F*rd sedan and is really pleased with the result,and as Waldo said they've been about for a while! So I guess they must be doing something right  Jock. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | I havent used theirs but did use the TCI rear leaf kit. supposed to be a 3-4 inch drop. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Same here, I used the TCI setup on my 55, with good results. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | used chassis engineering rear leaf kit,got almost a 5"drop...............dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Posies Springs are direct bolt in using the original hangers. Their springs are stock 1.75" wide. A good set up with minimal fuss. My friend used the Posies Springs in his '53 1/2 ton pick up.Lowered the truck nice. Chassis Engineering Springs use their own hangers which moves the spring center pin back to center the rear wheels in the fender opening. The end result looks good. Their springs are 2.5" wide and are shorter than the stock ones or the Posies Springs. Measure carefully when installing the Chassis Engineering spring kit hangers.Their specs aren't always exact. They're close but not exact. I've used their rear spring kits in 2 of my vehicles. I don't mind moving things around so that everything is square and true. If you don't measure and install these kits carefully, you'll be in for an unpleasant surprise when you go to the alignment shop. I believe Chassis Engineering and TCI buy their springs from a same manufacturer, but I'm not certain. The TCI hangers weld in , while the Chassis Engineering hangers bolt in. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | the kit from ce that i used,used some of the original bolt holes as a locator.kit went in very simple and yes,did center the rear wheels nicley.but i understand about checking measurements. the motor mounts had to be pulled forword a little for some extra firewall clearence for the distributor...........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | the kit from ce that i used,used some of the original bolt holes as a locator.kit went in very simple and yes,did center the rear wheels nicley.but i understand about checking measurements. the motor mounts had to be pulled forword a little for some extra firewall clearence for the distributor...........dave mine used the original bolt holes also and mine was TCI, I only had to drill one hole on each side. then I welded them for extra security. this is what I had to do for engine clearance, the LS based engines are even tighter than the older small blocks. http://i11.photobucket.com/albums/a198/ahsum/firewall4.jpg | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | the kit from ce that i used,used some of the original bolt holes as a locator.kit went in very simple and yes,did center the rear wheels nicley.but i understand about checking measurements. the motor mounts had to be pulled forword a little for some extra firewall clearence for the distributor...........dave mine used the original bolt holes also and mine was TCI, I only had to drill one hole on each side. then I welded them for extra security. this is what I had to do for engine clearance, the LS based engines are even tighter than the older small blocks. http://i11.photobucket.com/albums/a198/ahsum/firewall4.jpg uhhh.i'll stick to just movin the mounts.  ...,,,,,dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
